[GRASSLIST:6738] Re: GRASS and QGIS
geir.systad at nina.no geir.systad at nina.no
Mon May 9 06:15:44 EDT 2005
Thanks, Stephan-
To compile qgis under cygwin/windows might be a solution, so I will look into it in my linux system instead.
And I guess it might be just as easy to do the neccecary work by command line in grass, and use qgis as a viewer/layout tool?
Cheers, Geir
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> [mailto:owner-GRASSLIST at baylor.edu] On Behalf Of Stephan Holl
> Sent: Monday, May 09, 2005 10:49 AM
> To:
> Subject: [GRASSLIST:6735] Re: GRASS and QGIS
> Hello Geir,
> On Mon, 9 May 2005 10:25:19 +0200 geir.systad at nina.no wrote:
> > Hei-
> > I have started qgis within grass 6.1.cvs (Windows-Cygwin). I know
> > there is a grass toolbox somewhere, but the only reference to the
> > toolbox I can find, is
> > http://wiki.qgis.org/qgiswiki/Adding_New_Tools_to_the_GRASS_Toolbox.
> > Can anyone give me the right references/instructions/directions for
> > installing the grass toolbox in qgis?
> > Sincerely,
> > Geir Systad
> AFAIK there is no windows port for the necessary GRASS-Plugin
> for QGIS yet. So you need to compile QGIS with the needed
> GRASS_Plugin by your own.
> Please correct me if I am wrong (I am not up-to-date
> regarding to windows stuff...)
> Cheers
> 	Stephan
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office (TCH) -  Vahrenwalder Straße 7   -   D-30165 Hannover
> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> Phone : ++49-(0)511-9357560       -          Fax: ++49-(0)511-9357100
