[GRASSLIST:6740] Re: GRASS and QGIS
geir.systad at nina.no
Mon May 9 06:27:57 EDT 2005
I ment it might be easier to get things correctly configured under linux..
Geir
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> [mailto:owner-GRASSLIST at baylor.edu] On Behalf Of Systad, Geir
> Sent: Monday, May 09, 2005 12:16 PM
> To: holl at gdf-hannover.de
> Cc: grasslist at baylor.edu
> Subject: [GRASSLIST:6738] Re: GRASS and QGIS
> Thanks, Stephan-
> To compile qgis under cygwin/windows might be a solution, so
> I will look into it in my linux system instead.
> And I guess it might be just as easy to do the neccecary work
> by command line in grass, and use qgis as a viewer/layout tool?
> Cheers, Geir
> > [mailto:owner-GRASSLIST at baylor.edu] On Behalf Of Stephan Holl
> > Sent: Monday, May 09, 2005 10:49 AM
> > To:
> > Subject: [GRASSLIST:6735] Re: GRASS and QGIS
> > Hello Geir,
> > On Mon, 9 May 2005 10:25:19 +0200 geir.systad at nina.no wrote:
> > > Hei-
> > > I have started qgis within grass 6.1.cvs (Windows-Cygwin). I know
> > > there is a grass toolbox somewhere, but the only reference to the
> > > toolbox I can find, is
> http://wiki.qgis.org/qgiswiki/Adding_New_Tools_to_the_GRASS_To
olbox.
> > Can anyone give me the right references/instructions/directions for
> > installing the grass toolbox in qgis?
> > Sincerely,
> > Geir Systad
> AFAIK there is no windows port for the necessary GRASS-Plugin
> for QGIS yet. So you need to compile QGIS with the needed
> GRASS_Plugin by your own.
> Please correct me if I am wrong (I am not up-to-date
> regarding to windows stuff...)
> Cheers
> Stephan
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office (TCH) - Vahrenwalder Straße 7 - D-30165 Hannover
> Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
> Phone : ++49-(0)511-9357560 - Fax: ++49-(0)511-9357100
