[GRASSLIST:6743] Re: tcl-tk or qgis ?
Radim Blazek blazek at itc.it
Mon May 9 10:51:18 EDT 2005
Jachym Cepicky wrote:
> On Sat, May 07, 2005 at 02:56:19PM +1200, Hamish wrote:
>>I would write a shell script using the GRASS's g.parser[*]. Adding that
>>to the GUI in GRASS or in QGIS would be easy to do - just keep the logic
>>out of the GUI, use it as a front-end.
>>[*] see the included GRASS 6 scripts/ in the source distribution and
>>  http://grass.ibiblio.org/grass60/manuals/html60_user/g.parser.html
>> for ideas.
>>Hamish
> exactly!
That can work only until you need user interaction with map (e.g. select
area, select features, ...).
Here is example of an application based on GRASS but developed as QGIS
plugin:
http://community.qgis.org/uploadfiles/GRASS_Meeting_2005_4_english.pdf
http://www.acsys.it/riade/upload/testo_r/home_link/RIADE_ACS_GRASS_article.pdf
http://community.qgis.org/index.php?option=com_content&task=view&id=57&Itemid=2
Radim
