[GRASSLIST:6774] Re: problems importing shapefile ...
Radim Blazek blazek at itc.it
Fri May 13 03:39:39 EDT 2005
Oliver.Chikumbo at forestresearch.co.nz wrote:
> Hi Radim,
> Just noticed what i have done ... i went into db.connect and deleted the
> schema and reran the module. I twent back into v.in.ogr and when i ran it
> it still registered the schema. For some reason grass6 refuses to run
> without the schema. Is there something I need to do to ensure that the
> schema is turned off and not used in v.in.ogr
Does it take the schema you define?
Radim
> Cheers
> Ollie
> Oliver Chikumbo          (Forest Management Scientist)
> Forest Research
> Sala St
> Private Bag 3020
> Rotorua, New Zealand
> Ph: +64 7 343 5547     Fax: +64 7 343 5507
> E-mail: Oliver.Chikumbo at forestresearch.co.nz
