[GRASSLIST:6797] Re: Several plots in one
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Mon May 16 20:33:06 EDT 2005
You can also r.patch your rasters together, then use ps.map.
-Ian
On May 16, 2005, at 4:29 PM, Dylan Beaudette wrote:
> On Wednesday 11 May 2005 01:42 am, Glynn Clements wrote:
>> Jose Gomez-Dans wrote:
>>> So far, I have used d.rast for visualising some rasters. This is all
>>> very nice, and with d.frame I can plot a set of images as a matrix
>>> (say 3x3). I would like to produce some PostScript output now, and
>>> would not like to have to take a snapshot of the monitor screen and
>>> convert it to postscript. I can't see a way of (easily ;D) doing this
>>> with ps.map. Any ideas?
>> Export the rasters at their native resolution to image files then use
>> a graphics package to compose the page.
>> ps.map doesn't have the functionality you require, and nothing else in
>> GRASS is suitable for generating print-quality graphics.
> With GMT it should be possible to produce PS output.
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
