[GRASSLIST:6852] Re: Data corruption after v.digit crash
Radim Blazek
blazek at itc.it
Mon May 23 04:00:44 EDT 2005
Andrew Birkett wrote:
> Hi,
> I'm using grass-6.0.0 to create a vector version of some scanned
> out-of-copyright maps. At one point, v.digit froze and after a while I
> had to kill the process. Upon restarting, I can display my vector map
> using d.vect but I get a warning "coor files of vector 'foo at PERMANENT'
> is larger than it should be'. From reading around, this is to be
> expected since v.digit writes out the length data on exit.
It would be possible but probably too slow (I think) to rewrite the size
always when a new line is written (hard disk head jumps?).
If anybody is interested, it is possible to try to add
Vect_coor_info ( Map, &CInfo );
Map->plus.coor_size = CInfo.size;
dig__write_head (Map);
into
V1_rewrite_line_nat()
> The recommend fix is to rerun v.digit to rewrite the file.
> However, if I try to run v.digit I get the following error;
> "ERROR: Cannot open old vector foo at PERMANENT on level 2"
> I get the same error if I try to export the dataset using v.out.ogr.
You have to run v.build, it is always necessay after crash.
> Now, my vector dataset was created today in grass 6.0 so I don't imagine
> it uses the old vector format. Certainly, "g.list type=vect" shows my
> map and "g.list type=oldvect" doesn't.
> Any idea how I can recover my data? I was only doing a small amount of
> work today to test-drive grass6, but since v.digit crashed once it's
> reasonable to assume I'll encounter this again when I do the map for
> real.
> Secondly does grass6 allow you to store the geometry of a vector map in
> a postgis table? (I've been storing attributes on a pg table). I'd
> feel a bit happier if my data was being updated with transactions to
> avoid crash-lossage like this.
No.
Radim
> Thanks in advance for any help. Today is the first day I feel that I've
> got into the "grass way" of thinking about things.
> Andrew
