[GRASSLIST:6893] v.proj problem
Francesco Mirabella mirabell at unipg.it
Thu May 26 10:27:14 EDT 2005
Hi to all,
I have reprojected 3d vector points from wgs84 lat long location to
utm33:
-in the UTM 33 location:
v.proj input=data_wgs84  output=data_utm33 location=WGS_84_latlong mapset=PERMANENT
I got the following error:
Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=utm +zone=33 +a=6378388 +rf=297
+no_defs +towgs84=-87.000000,-98.000000,-121.000000
Output Unit Factor: 1
Creating vector file...
pj_transform() failed
cause: geocentric transformation missing z or ellps
Error in pj_do_transform
GRASS 6.0.0 (umbmar):~ >
can someone help?
Francesco
p.s.
I did v.proj transformations some other times from the same location
into the utm33 location, but it is the first time that this error
occurred.
