[GRASSLIST:6892] Re: Arc/Info Binary grid conversion
Eric Hillmuth hillmuth at verizon.net
Thu May 26 10:05:40 EDT 2005
Yeah its a bit tricky, you can specify the adf file within the
directory  for input and it works fine.
Michael Kowen wrote:
>Hello everyone,
>I am (also) very new to using grass.
>I am trying to import (to a new location) a DEM from an esri database.
>The map's current type is an Arc/Info Binary grid (or .adf file).  I
>know that this file type is supported in gdal, and that it can be
>imported to a raster/new location using r.in.gdal -eo and so forth.  My
>problem is that the complete map is actually stored in a structure (of a
>sort) involving 5-6 files.  The documentation for r.in.gdal and its
>interaction with Arc/Info binary grids says that you can specify the
>"coverage directory," but the command does not accept input="dir."  Is
>there some extra option that allows this usage?  What is the best
>technique for importing this type of file?
>Thanks,
>Michael Kowen
