[GRASSLIST:6948] Re: multiple users issue
Daniel Gavin
Daniel.Gavin at uvm.edu
Mon May 30 10:38:38 EDT 2005
At 3:05 PM +0300 5/30/05, =?ISO-8859-13?Q?M=E2ris_Narti=F0s?= wrote:
>Hi,
>Which distribution you use? The best way to avoid such problems is to
>install GRASS from distribution packages.
>How You compiled GRASS? Is GRASS installed in /usr/bin or
>/usr/local/bin or /root/grass ?
>Error "command not found" means that grass command is not in your
>users PATH. Add to Your users .~bashrc string
>"PATH=$PATH:/path/to/grass/executable"
It is in /usr/local/bin, installed from the binaries distributed
online. I thought the PATH was set correctly, but I will check next
time I am back at that computer (tomorrow).
Thanks,
Dan
>Maris.
>PS. If You use Gentoo, right command is "grass60"!
>On 5/28/05, Daniel Gavin <Daniel.Gavin at uvm.edu> wrote:
>> We wish to use GRASS 6.0/6.1 on a computer with users using different
>> accounts. It was installed by a root user and it runs fine from that
>> account. However, we can't seem to get a non-root user to start the
>> program. I have created a local .grassrc6 file. Typing 'grass6' at
>> a prompt returns something like 'command not found', and the icon
>> start-up just quits. I assume this is something quite simple!
>> Many thanks.
>> Dan Gavin
>> Research Associate
>> University of Vermont
>> Botany and Agricultural Biochemistry
>> 120B Marsh Life Science
>> 109 Carrigan Dr.
>> Burlington, VT 05405-0086
>> 802.656.0297
Dan Gavin
Research Associate
109 Carrigan Dr.
