[GRASSLIST:6947] Re: multiple users issue
    Māris Nartišs
    maris.nartiss at gmail.com
    Mon May 30 08:05:58 EDT 2005
Which distribution you use? The best way to avoid such problems is to
install GRASS from distribution packages.
How You compiled GRASS? Is GRASS installed in /usr/bin or
/usr/local/bin or /root/grass ?
Error "command not found" means that grass command is not in your
users PATH. Add to Your users .~bashrc string
"PATH=$PATH:/path/to/grass/executable"
Maris.
PS. If You use Gentoo, right command is "grass60"!
On 5/28/05, Daniel Gavin <Daniel.Gavin at uvm.edu> wrote:
> We wish to use GRASS 6.0/6.1 on a computer with users using different
> accounts.  It was installed by a root user and it runs fine from that
> account.  However, we can't seem to get a non-root user to start the
> program.  I have created a local .grassrc6 file.  Typing 'grass6' at
> a prompt returns something like 'command not found', and the icon
> start-up just quits.  I assume this is something quite simple!
> Many thanks.
> Dan Gavin
> Research Associate
> University of Vermont
> Botany and Agricultural Biochemistry
> 120B Marsh Life Science
> 109 Carrigan Dr.
> Burlington, VT 05405-0086
> 802.656.0297
