[GRASSLIST:6961] Re: GRASS 6 gdal support for netcdf format
Thomas Adams
Thomas.Adams at noaa.gov
Tue May 31 09:52:50 EDT 2005
Hamish,
Thanks for your help! No, I do not see;
r.in.gdal -f in=foo out=bar | grep -i cdf
GMT (rw): GMT NetCDF Grid Format
netCDF (ro): network Common Data Format
when I run 'r.in.gdal -f in=foo out=bar | grep -i cdf
So, your best guess is that a gdal lib is being picked up without netcdf
support. I'm not sure how this can be since I built all the libs. Due to
local admin restrictions I had to put the gdal libs (and proj libs,
etc.) in with the GRASS libs. How can I be sure that the gdal lib
correctly built with netcdf support?
I do have one question, when building gdal, am I suppose to set the flag
for GRASS support? I tried that once and got some error, so I *maybe*
mistakenly thought that I should not do that.
Regards,
Tom
Hamish wrote:
>>I need to import netcdf files into GRASS 6.0.0. I successfully built
>>GRASS 6.0.0 with gdal support (and previously built gdal with netcdf
>>support), but when I try to import the netcdf file, GRASS tells me
>>it's an unsupported format. The r.in.gdal -f option confirms that
>>netcdf is not supported as it is available in GRASS. I don't
>>understand.
>does this list it?
>gdalinfo --formats
>if so it should work with GRASS too, but make sure you don't have
>multiple GDAL libraries installed, GRASS might be picking up the one
>without netcdf support.
>Quick solution:
> convert to a GeoTIFF or something with 'gdal_translate' and load that.
>Hamish
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050531/97ef46bb/attachment.html
