[GRASSLIST:6956] Re: georeference vector map and transform from xy location to long/lat projection
Markus Neteler neteler at itc.it
Tue May 31 05:16:15 EDT 2005
On Mon, May 30, 2005 at 09:53:01PM +0200, Andreas Rathgeber wrote:
> Hello all,
> I have a outside of GRASS digitized vector map (original map was
> image with distortion and some rotation) loaded into an XY
> location. This location also contains the original image.
> Now I want to georeference both maps into my target location that
> has a long. / lat. projection.
> I've created a pointsfile based on the original image. I have no
> problem to georeference the image into my target location with
> the target projection.
> Where I struggle is the georeferencing of my vector map into the
> target location.
> I was thinking about v.proj, v.transform to do it.
> With v.transform and the pointsfile from my image I was able to
> remove the distortion and do the rotation. But this only leads to
> a much reduced size and the question how I get the vector map
> into my target location. The v.proj seems not possible as in an
> XY location no PROJ_INFO is available - and what certainly make
> sense when one understand how the georeferencing of vector maps
> is done ;-)
> Can someone point me to the correct order of the steps I should
> perform?
If you want to apply only linear stretch etc., load the vector
map directly into the target location and then use v.transform.
Markus
