[GRASSLIST:8854] RE: table of x, y and z points
Tiago Salgueiro
1010664 at isep.ipp.pt
Thu Nov 3 06:54:02 EST 2005
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
> Behalf Of 1010664 at isep.ipp.pt
> Sent: Wednesday, November 02, 2005 3:01 PM
> To: GRASSLIST at baylor.edu
> Subject: [GRASSLIST:8844] table of x, y and z points
> Hi all,
> With a table of x, y znd z points can I have the correspondent map? Is
> this
> possible with GRASS? How can I make it?
> Thanks!
> Best Regards,
> Tiago Salgueiro
> Yes, if you have a database table (dbf), you can use v.in.db; if you have
> a
> plain ascii text file, use v.in.ascii.
> Read:
> http://grass.itc.it/grass61/manuals/html61_user/v.in.ascii.html
> http://grass.itc.it/grass61/manuals/html61_user/v.in.db.html
> Hope this helps,
> ~ Eric.
> Eric Patton
> Technologist, Geo-Spatial Data Services
> Geological Survey of Canada (Atlantic)
> Natural Resources Canada
> Bedford Institute of Oceanography
> Dartmouth, Nova Scotia, Canada B2Y 4A2
> Postal address: P.O. Box 1006
> Courier address: 1 Challenger Drive
> Telephone: (902)426-7732
> Facsimile: (902)426-4104
> E-mail: epatton at NRCan.gc.ca
Dear all,
I have for example the following text file called teste:
x y z
1 2 3
2 3 2
4 5 1
3 1 2
I tried
$ v.in.ascii -z input=/home/teste fs=tab skip=1
and nothing happens.
Is the command correct?
Thanks
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
