[GRASSLIST:8866] RE: table of x, y and z points
Thu Nov 3 18:27:24 EST 2005
> I have for example the following text file called teste:
> x	y	z
> 1	2	3
> 2	3	2
> 4	5	1
> 3	1	2
> I tried
> $ v.in.ascii -z input=/home/teste fs=tab skip=1
> and nothing happens.
> Is the command correct?
What do you mean by "Nothing happens"?
Without an output=map_name it gives an error, and without z=3 it says
"ERROR: Please specify z column."
So try:
GRASS 6.1> v.in.ascii -z z=3 input=/home/teste fs=tab skip=1 output=test
Hamish
