[GRASSLIST:8893] RE: table of x, y and z points
Tiago Salgueiro
1010664 at isep.ipp.pt
Fri Nov 4 15:31:40 EST 2005
> ---------Original Message-----
> Subject: Re: [GRASSLIST:8853] RE: table of x, y and z points
>> Like you said I try the following:
>> $v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
> fs=tab skip=1 columns='x double precision, y double precision, z double >
> precision, cat int' \ x=1 y=2 z=3 cat=0
>> with teste file like this:
> x y z
> 1 1 1
> 2 2 2
> 3 3 3
> 4 4 2
> 5 5 1
> GRASS just didn't made anything. Do you have some idea about what is
> wrong?
> Tiago Salgueiro
> Try typing
> g.list vect
> Do you see your output file 'teste_out'? If so, you will have to set your
> region to that of your new vector:
> g.region vect=teste_out
> Then,
> d.vect map=teste_out
> as Hamish already mentioned. Incidentally, I tried entering the exact same
> v.in.ascii commands you listed above, with the same xyz file and it worked
> perfectly.
> ~ Eric.
I tried exactly entering the commands you said but nothing. Grass didn't
answer anything, no error message, no files list just blocked and I press
CTRL+C to abort.
I installed the grass rpm for suse linux but my linux version is not
exactly this one. I've a portuguese distribution called CaixaMágica that
is derivated from suse. I'll try install fedora during the weekend and
after that I ask for your help again.
Thanks!!
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
