[GRASSLIST:8908] RE: table of x, y and z points
Mon Nov 7 01:06:31 EST 2005
> > Subject: Re: [GRASSLIST:8853] RE: table of x, y and z points
> >> Like you said I try the following:
> >> $v.in.ascii -z input=/home/tiago/teste output=teste_out
> >format=point
> > fs=tab skip=1 columns='x double precision, y double precision, z
> > double > precision, cat int' \ x=1 y=2 z=3 cat=0
> >> with teste file like this:
> > x	y	z
> > 1	1	1
> > 2	2	2
> > 3	3	3
> > 4	4	2
> > 5	5	1
> > GRASS just didn't made anything. Do you have some idea about what is
> > wrong?
> I tried exactly entering the commands you said but nothing. Grass
> didn't answer anything, no error message, no files list just blocked
> and I press CTRL+C to abort.
Ahh, it hangs and you need to press CTRL-C. That is something.
If you run "top" in another window or "gkrellm" is the processor usage
stuck at 100%? ie is it endlessly searching for more data? What if you
press ctrl-d? Which version of GRASS was this again?
What is the output of "file /home/tiago/teste" ?
Hamish
