[GRASSLIST:8941] Re:
Ing.Peter Misovic peter.misovic at gmail.com
Tue Nov 8 16:18:51 EST 2005
Dear all,
as I can see, there is a misunderstanding beetween you guys. If I
understood it well, Peter wants to add new symbol to 3D NVIZ. Not in
2D Manager as you understood it at all. Of course, 2D symbol can be
added in very simple way. Source for 2D symbol is se to
$GISBASE/etc/symbols. But he wants to know, where is the storage (or
source) for symbols used in NVIZ (actualy Diamond, Spehere and X are
showed) ? As I can see from pasted code, he tried to use box, but with
no effect at all.
Peter
On 11/8/05, Hamish <hamish_nospam at yahoo.com> wrote:
> > > > I tryed change existing symbol (diamound) before compilation .
> > > > When copmpilation finised symbol succesfull changed only in 2D in
> > > > NVIZ symbol diamound doesn't changed.
> > > > How I can cerating new symbol but editing in NVIZ???????(now is
> > > > X,diamound and sphere)
> > > That is unreleated to the vector point symbols. You'd have to look
> > > in the nviz code. see visualization/nviz/src/map_obj.c in the source
> > > code. (cube, trees, etc in there already??)
> > > also visualization/nviz/scripts/panel_site.tcl
> > > You don't need to recompile to edit the symbols by the way. Just
> > > edit/add to $GISBASE/etc/symbols. But keep a backup in case of
> > > reinstall.
> > I try your solution I modified panlel_site.tcl
> > radiobutton $tmp.siteshape.x -relief flat -text "use X" -value x \
> > -anchor nw -variable Nv_(siteshape) -command change_marker
> > radiobutton $tmp.siteshape.sphere -relief flat -text "use sphere" \
> > -value sphere -anchor nw -variable Nv_(siteshape) \
> > radiobutton $tmp.siteshape.diamond -relief flat -text "use diamond" \
> > -value diamond -anchor nw -variable Nv_(siteshape) \
> > radiobutton $tmp.siteshape.box -relief flat -text "use box" \
> >  -value box -anchor nw -variable Nv_(siteshape) \
> >  radiobutton $tmp.siteshape.cube -relief flat -text "use cube" \
> >  -value cube -anchor nw -variable Nv_(siteshape) \
> > pack $tmp.siteshape.x $tmp.siteshape.sphere $tmp.siteshape.diamond
> > $tmp.siteshape.box
> > $tmp.siteshape.cube \
> > Its all? Because nothing displayed when I click on cube ,box. Other
> > symbols is correct.
> > What is the wrong??
> I don't know- it was just a guess. I don't know if it is simple or
> hard to fix, maybe someone else more familiar with the NVIZ code can
> comment.
> Hamish
