[GRASSLIST:8966] Re: GRASS 6 in a nutshell tutorial
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Wed Nov 9 19:52:21 EST 2005
Luigi, glad that you mostly got things to work. Good to know that
there are alternate sources of data. I am not sure, but I would guess
that you are using a UTM projection. I bet that the vector is using
one zone, and the DEM is using another. Make sure that you import them
into their true projection, then reproject the data as you see fit (I
would reproject the vector to save time).
Just for completeness, I think GRASS can import e00 vectors without too
much trouble with v.in.e00.
-Ian
On Nov 9, 2005, at 11:10 AM, Luigi Ponti wrote:
> Thanks Ian,
> I got the vector .shp outline of the state from the California Spatial
> Information Library http://gis.ca.gov/index.epl since the one you
> recemmended me on http://data.geocomm.com/ was in .e00 format and
> GRASS would not import it directly.
> The DEM I got it from NOAA/GLOBE
> http://www.ngdc.noaa.gov/mgg/topo/globe.html where you can customize
> your download area as opposed to the DEM on http://seamless.usgs.gov
> that has to be downloaded in small pieces.
> I have imported both the vector and the raster with minimum trouble,
> since the first has a .prj file which GRASS recognized, and the second
> had a detailed import tutorial in the cygwin-GRASS install page.
> However, despite the fact the the two layers supposedly have the same
> NAD83 projection info (I did not enter anything manually), when I try
> to display them together on a GRASS monitor, the state layout is in
> the middle of the ocean compared to the elevation raster.
> Is there a way to overlap the two layers or to chek for a coordinate
> error?
> Thanks,
> Luigi
> Ian MacMillan wrote:
>> Luigi, I am not sure about your manual problems, but you can grab
>> data of California from several location for free. Try
>> http://data.geocomm.com/ for a vector outline of the state. You have
>> to create an account on that site, but it is free, and they have a
>> lot of useful data.
>> The best DEM of the state can be had from the USGS seamless server
>> here: http://seamless.usgs.gov. DEMs of a variety of resolutions are
>> available there.
>> If you have already imported data and can't view it, have you made
>> sure to set your region?
>> g.region rast=your_rast
>> or
>> g.region vect=your_vect
>> then
>> d.rast rast=your_rast
>> Hope this helps,
>> Ian
>> On Nov 3, 2005, at 3:58 PM, Luigi Ponti wrote:
>>> Markus Neteler wrote:
>>>> Luigi Ponti wrote:
>>>>> Hi there,
>>>>> while going through the Neteler's GRASS 6 in a nutshell tutorial I
>>>>> get
>>>>> the message:
>>>>> "Cannot open database
>>>>> /home/Administrator/grassdata/spearfish60/user1/dbf/ by driver dbf"
>>>>> when at section 3.1.2. I try to import vector ESRI SHAPE files form
>>>>> the package tiger2000_UTM13_nad27.tar.gz, via the "import various
>>>>> formats using ogr" option in the GIS manager.
>>>>> Does anybody know what the problem could be?
>>>>> Thanks,
>>>> Luigi,
>>>> please check if the directory
>>>> exists. If not, please create it. From current GRASS 6.1-CVS
>>>> onwards the
>>>> dbf/ directory in the current
>>>> mapset is created automatically.
>>>> Hope this helps
>>>> Markus
>>> Thanks Markus,
>>> It worked out perfectly fine.
>>> Now I would need to create my own location with a state boundary and
>>> an elevation model for California (this would provide the basis to
>>> map the output of my ecological model --reminder). Does anybody
>>> know if there is online files available for download that would
>>> allow me to accomplish such task? I have been trying to do this by
>>> OGR importing ESRI .shp files from http://gis.ca.gov/ into a
>>> location with projection based on .prj file content, but the new
>>> layer does not show up in the monitor. Any hints?
>>> Also when I try to access GRASS help, the following message shows up:
>>> "help /usr/local/grass6.0.0/scripts/g.manual: line 71: iexplore:
>>> command not found".
>>> Is it that GRASS cannot find the browser?
>>> Finally, when trying to access the man version via "g.manual -m
>>> d.rast", the shell says:
>>> "fopen: No such file or directory
>>> Cannot open man page
>>> /home/Administrator/C:\cygwin/usr/local/grass6.0.0/man/man1/
>>> d.rast.1.gz
>>> No manual entry for
>>> C:\cygwin/usr/local/grass6.0.0/man/man1/d.rast.1".
>>> Is there any fix to this?
>>> Ciao,
>>> Luigi
>> What happens if a big asteroid hits Earth? Judging from realistic
>> simulations involving a sledge hammer and a common laboratory frog,
>> we can assume it will be pretty bad.
>> - Dave Barry
>> This message has been scanned by Postini anti-virus software.
simulations involving a sledge hammer and a common laboratory frog, we
- Dave Barry
