[GRASSLIST:8986] Re: v.in.ascii error
Eva L. Hulse
evahulse at buffalo.edu
Thu Nov 10 14:54:12 EST 2005
Try formatting the file like this:
1|1|1
2|2|3
3|3|1
4|4|2
5|5|3
6|6|4
with | as the field delimiter, and in point rather than standard output
format:
v.in.ascii input=/home/salgueit/testar.txt output=testar1_out
format=point fs=| skip=1 'columns=x double, y double, z double' x=1 y=2
z=3 cat=0 -z
If that works, view the map by setting the region to match the new
vector file (use g.region), opening a diplay monitor and then using the
command d.vect to display the new vector file.
eva.
Tiago Salgueiro wrote:
> I give up to use grass with fedora core 3. Now I'm runing grass under
> Windows Xp. And my problem now is the following:
> with th file testar.txt:
> x y z
> 1 1 1
> 2 2 3
> 3 3 1
> 4 4 2
> 5 5 3
> 6 6 4
> AND THE COMMAND:
> format=standard fs=tab skip=1 x=1 y=2 z=3 cat=0 -z
> GRASS RETURNED:
> Error reading ascii file:
> 1 1 1
> Building topology ...
> Registering lines:
> 0 primitives registered
> Building areas:
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids: Topology was built.
> Number of nodes : 0
> Number of primitives: 0
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
> Am I doing something wrong? After I have success with this how can I see
> the map generated?
> Thanks!
> _____________________
> Cumprimentos/Best Regards,
> Tiago Salgueiro
> Nº1010664
Eva L. Hulse
PhD Student
University at Buffalo Anthropology Department
