[GRASSLIST:8984] v.in.ascii error
Tiago Salgueiro
1010664 at isep.ipp.pt
Thu Nov 10 14:15:18 EST 2005
I give up to use grass with fedora core 3. Now I'm runing grass under
Windows Xp. And my problem now is the following:
with th file testar.txt:
x y z
1 1 1
2 2 3
3 3 1
4 4 2
5 5 3
6 6 4
AND THE COMMAND:
v.in.ascii input=/home/salgueit/testar.txt output=testar1_out
format=standard fs=tab skip=1 x=1 y=2 z=3 cat=0 -z
GRASS RETURNED:
Error reading ascii file:
1 1 1
Building topology ...
Registering lines:
0 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Am I doing something wrong? After I have success with this how can I see
the map generated?
Thanks!
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
NÂș1010664
