[GRASSLIST:9215] Re: join two vector maps
Maciek Sieczka
werchowyna at epf.pl
Thu Nov 24 09:50:03 EST 2005
On czw, 2005-11-24 at 09:19 +0100, Josip Vrlić wrote:
> Hello!
> I don't know how to join two vector maps. Both maps are on different
> geo position, and have same collumns in database. I want to spare them
> in one map with table that will have rows from both maps. Problem is
> that both maps have collumn "cat" with same values.
Wn Grass 6.01 v.patch will do for merging geometry only, v.append for
both geometry and datatables.
However, v.append is slow which is a pain for big datasets.
In Grass61 Radim Blazek has recently added merging datatables
functionality to v.patch, kudos to him. It should be faster than
v.append. To use, you would need to fetch the source code from CVS and
compile it, or wait for the next CVS binary snapshot, generated weekly.
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
