[GRASSLIST:9260] Re: restrict vector map to current region
Huidae Cho
grass4u at gmail.com
Wed Nov 30 12:34:23 EST 2005
You cannot directly access to http://geni.ath.cx/grass since the web server
blocks listing of a directory. Instead, go to http://geni.ath.cx/grass.html and
follow links or run Cygwin setup.exe and enter http://geni.ath.cx/grass into
the user url. It will work even though you're forbidden to see the directory
via HTTP.
Huidae Cho
On Wed, Nov 30, 2005 at 06:05:24PM +0100, tsc44967 wrote:
> Hello,
> I imported some (large) vector maps of which most is outside my region, and
> therefore not of interest. As the maps take quite a lot of disk space, I would
> like to know if it is possible to remove the part of the map which is outside
> my region...
> And then something unrelated: the wingrass depository
> http://geni.ath.cx/grass/ gives a "forbidden" error. Does anyone know who to
> contact for this, or whether a mirror exist? (I have to give a GRASS workshop
> next friday, and they want to install GRASS on some (windows) computers so
> it's rather urgent)
> thanks!
> Wouter
> NOTE! My email address is changing to ... @scarlet.be
> Please make the necessary changes in your address book.
