[GRASSLIST:8478] Re: New GIS Manager version
Michael Barton
michael.barton at asu.edu
Tue Oct 4 02:15:06 EDT 2005
Ian,
Looking at your jpg, I think it is actually working OK. Have you tried doing
the same thing with d.his to compare?
I'm looking especially at the crater in the upper center of the aerial
photo. It has the grey shades of the aerial, but seems to have the relief of
the underlying map. The problem is that it is very difficult to see with
grey on grey. Try it with a color image draped on a relief map.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Ian MacMillan <ian_macmillan at umail.ucsb.edu>
> Date: Wed, 21 Sep 2005 07:09:06 -0700
> To: Michael Barton <michael.barton at asu.edu>
> Cc: GRASS Users List <grasslist at baylor.edu>
> Subject: Re: [GRASSLIST:8365] Re: New GIS Manager version
> Michael, I have only one raster in the GIS manager when I do this. If
> I put a grayscale shaded relief map in the first, and an air photo in
> the second, then I get an 'his' display that is later covered by just
> the first map. I have attached a small jpg that shows what I am
> talking about. This screen shot shows my 'his' image getting covered
> up by the shaded relief map (the shaded relief map does not extend all
> the way to the outer bottom right edge). For some reason it looks like
> I am getting something like
> d.his h_map=air_photo i_map=shaded_relief
> d.rast shaded_relief -o
> rather than just the d.his command when I hit the display button.
> I am also using the binaries from Lorenzo (Sept. 17 - source, Sept. 19
> - osx). That is weird that you can't reproduce this.
> -Ian
> On Sep 20, 2005, at 11:40 PM, Michael Barton wrote:
>> Ian,
>> You are correct that a version of d.his is called when you drape or
>> fuse
>> maps.
>> I just checked this with the version of Lorenzo's binaries I downloaded
>> today, with the new GIS Manager installed.
>> It seemed to work exactly as you'd expect it to work. I added a dem to
>> the
>> 1st raster map entry field and an ASTER image to the second. I got the
>> ASTER
>> shaded by topography. I reversed them and got an image that looked
>> pretty
>> similar. Do you have another layer in the GIS Manager that is
>> overwriting
>> the first one?
>> I have the overlay checkbox selected by default in all raster layers.
>> But if
>> you turn it off, a layer will overwrite all preceeding layers.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Tue, 20 Sep 2005 17:06:10 -0700
>>> To: GRASS Users List <grasslist at baylor.edu>
>>> Subject: [GRASSLIST:8365] Re: New GIS Manager version
>>> Hey there Michael, fantastic job on the new GIS Manager. Looks great
>>> so far. I have a question about the functionality of the d.rast
>>> button. In the menu options there is a button that says 'Raster to
>>> drape over 1st map'. This seems like an approximate d.his utility.
>>> However I don't quite understand how it works. Say if I have map1
>>> (air
>>> photo) under 'Raster name' and map2 (DEM) under the second button,
>>> then
>>> when I display the image I get what I think is my colored DEM with
>>> shading from my black and white air photo. This then gets covered up
>>> by map1 (the monitor displays two images overlain on top of each
>>> other).
>>> Does my explanation make sense? Is that second raster not supposed to
>>> display? How does this button differ from d.his?
>>> Cheers,
>>> Ian
>>> PS using mac 10.3.9
>>> What happens if a big asteroid hits Earth? Judging from realistic
>>> simulations involving a sledge hammer and a common laboratory frog, we
>>> can assume it will be pretty bad.
>>> - Dave Barry
>>> This message has been scanned by Postini anti-virus software.
> - Dave Barry
