[GRASSLIST:8480] Re: d.m - commands output pollute the Grass terminal
Michael Barton
michael.barton at asu.edu
Tue Oct 4 02:34:55 EDT 2005
Maciek,
I've been out of town and am just now getting caught up on my email.
This is a "feature" rather than a bug. At least that was my intent.
When you run a command from its individual tcltk module (i.e., started from
the command line or a menu item), it prints the command in the output
window. You can copy it from there and use it on the command line or paste
it into a command layer in the GIS manager.
When I moved all display commands to buttons/panels in the GIS manager, this
option was lost. So I had these particular commands output to the terminal
so that people could copy them and use them elsewhere.
Hamish has tried a different shade of green and put it in the cvs. He also
made a single line in the d.m.tcl code where you can change the color to
whatever you want. I haven't tried it yet.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: 23 Sep 2005 16:47:17 +0200
> To: <grasslist at baylor.edu>
> Cc: <michael.barton at asu.edu>
> Subject: [GRASSLIST:8396] d.m - commands output pollute the Grass terminal
> Michael,
> Thanks for the enhanced d.m, looks better and is more functional. I really
> appreciate your work!
> Question - is it intended that all the commands text output is printed in the
> Grass terminal? Not that it is something new - it's always been like that. But
> now that I try to use the your new d.m more than before I find it pretty
> annoying, as I'm working both from d.m and terminal. Could there be a separate
> terminal window for all the warnings and other text output from d.m commands,
> to avoid polluting the main Grass terminal?
> Maciek
> P.S.
> I think I'm not the only one not so found of the flashy green :).
> Samoobrona lista nr. 15 www.samoobrona.org.pl
