[GRASSLIST:8526] Re: troubleshooting Cygwin and Grass 6 installation
Paulo Froes froesp at yahoo.com
Thu Oct 6 14:21:14 EDT 2005
Dear Eva,
thanks a lot.
It seems I have installed Grass 6.1 cvs and also the 6.0 (geni/ath/cx seems to be working again!).
I even managed to start up Grass 6.1 ( and also the 6.0). But in both situations I am getting the following messages:
Warning: Invalid Database
Warning: Invalid database. Finding first valid directory in parent tree.
After OKing the warning message and trying the browse button (both versions)  to set the directory  where I have saved already the "spearfish57" (.../database/) I am getting  the following message, no matter what:
Application error
Error: couldn't change working directory to "./database": no such file or directory.
Could you (or maybe some other user ) still help?
Thank you very much once again in advance for your attention and patience...
Paulo
"Eva L. Hulse" <evahulse at buffalo.edu> wrote:
I am running Grass 6.1.cvs on Cygwin/Windows XP. I once had a similar
problem with the cygwin install. This was because I added only:
http://geni.ath.cx
as a download site. I should have added it as:
http://geni.ath.cx/grass
Although once the download site is added, you won't see the "/grass"
part on the list. I don't know if this is the problem you are having.
I didn't have to follow any special instructions to get things to work
under XP.
In the past, I have also installed the Grass files manually, after
installing Cygwin only. The instructions for this are under the header
"Alternative installation for 6.1 CVS" on http://geni.ath.cx/grass.html.
This bypasses the download site completely
-- you just need to connect to one of the sites that has the base Cygwin
files. Of course, then you'll be running the CVS version, and not the
release version. But that shouldn't be a problem.
eva.
Paulo Froes wrote:
> Dear Grass users,
> Could someone help me with CYGwin and GRASS 6 installation under Windows
> XP? I am having a hard time to install Grass and the web tutorials seem
> to be of no help to overcome specifics...
> When trying to restart the installation process using CYGwin setup,
> following the step "choose a download site" and after adding
> http:/geni.ath.cx/ to the list and selecting it together with another
> mirror site, I am getting the following error messages:
> Cygwin Setup:
> Can't open http:/geni.ath.cx/grass/setup.bz2 for reading: Invalid argument
> Cygwin Setup:
> Unable to get setup.ini from
> Many thanks in advance for any help. Would appreciate as well if
> someone has written an alternative step by step installation "guide"
> under Windows XP and could share it...
> Paulo
Eva L. Hulse
PhD Student
University at Buffalo Anthropology Department
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051006/d1863d82/attachment.html
