[GRASSLIST:8528] Re: EPSG: Basic question...
Christian Ferreira christian.grass at gmail.com
Thu Oct 6 16:59:12 EDT 2005
Thanks Hamish,
> http://www.epsg.org/
> has the full database,
Yes, I saw this, but I don't use Windows or MS Access. But maybe I will try
to set a database with Postgresql/Mysql.
but for the PROJ.4 supplied version that GRASS
> uses hunt for a file called something like /usr/share/proj/epsg on
> your system. Open that in a text editor and search. A quick look turns
> up two codes, 29100 and 29101. Codes for WGS84 lat/lon etc are in the
> article text.
> $ grep -A1 Brazil /usr/share/proj/epsg
> # SAD69 / Brazil Polyconic
> <29100> +proj=poly +lat_0=0 +lon_0=-54 +x_0=5000000 +y_0=10000000
> +ellps=GRS67 +units=m +no_defs <>
> <29101> +proj=poly +lat_0=0 +lon_0=-54 +x_0=5000000 +y_0=10000000
> +ellps=aust_SA +units=m +no_defs <>
BTW: The list included on GRASS (On "Create location From ESPG => EPSG
Codes") is endless. It's really hard to find anything. I think that a search
engine is necessary for it.
Again, thank you for your help.
Cheers,
Christian dos Santos Ferreira
Oceanographer. Msc.
Lab. of Fisheries Research and Hydroacustics
Federal University of Rio Grande (FURG)
Rio Grande - RS - Brazil
Tel +55 (53) 32336528
Website: http://poseidon.furg.br
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051006/e765d2fa/attachment.html
