[GRASSLIST:8541] Re: compiling GRASS on mac os x
William Kyngesburye
woklist at kyngchaos.com
Fri Oct 7 12:41:52 EDT 2005
I've been a bit bogged down to do anything with the build
instructions or my own binaries. Here's what you do:
Edit configure. Find the section that starts with 'Rhapsody-*|Darwin-
*)' - there are two, the second is an empty case, you want the
first. Add -fno-common to SHLIB_CFLAGS, like:
SHLIB_CFLAGS="-fno-common"
make sure to leave the leading space as it is in configure.
And in the SHLIB_LD string, change '-single_module' to '-
flat_namespace'. That has worked for me so far with 6.0.1 and
6.1CVS. I still need to try different combinations, but this works
so far.
Feedback would be nice - I *still* haven't got around to playing with
NVIZ or even the Tcl GUI, just pounding away in the Terminal.
On Oct 7, 2005, at 10:39 AM, William A. Perkins wrote:
> Hello,
> I have a related question.
> I use Lorenzo's GRASS 6 CVS binaries on Mac OS X 10.3.9 and they work
> great on my G5 and G4 systems. I also keep the latest CVS source so I
> can muddle with it. I have no difficulty compiling the CVS source,
> but I have two complaints about the resulting binaries:
> 1. All of the general/manage utilities (g.copy, g.remove, etc.)
> crash with a Bus Error. I've tracked this with a debugger and
> it seems to be happening in init(), possibly read_list(), but I
> can't really tell because the stack gets corrupted. As you can
> imagine, this is very inconvenient.
> 2. Any invocation of Tk-based apps are very slow compared to
> Lorenzo's binary distribution (this is not a GRASS problem; the
> wish from fink is slow).
> I've studied the Mac OS X build instructions and the mailing lists and
> have not located a solution to 1. I must be missing something simple
> because the distributed binaries work so well. Any hints would be
> appreciated.
> I get all library requirements from fink. I use gcc_select 3.3; 3.1
> segfaulted in lib/ogsf. My configuration is as follows:
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
