[GRASSLIST:8542] Re: compiling GRASS on mac os x
William Kyngesburye
woklist at kyngchaos.com
Fri Oct 7 12:50:24 EDT 2005
I'm sorry, -fno-common and -flat_namespace is the way it is now.
What I meant to say is:
remove -fno-common from SHLIB_CFLAGS (so it's an empty string) and in
SHLIB_LD change '-flat_namespace' to '-single_module'.
On Oct 7, 2005, at 11:41 AM, William Kyngesburye wrote:
> I've been a bit bogged down to do anything with the build
> instructions or my own binaries. Here's what you do:
> Edit configure. Find the section that starts with 'Rhapsody-*|
> Darwin-*)' - there are two, the second is an empty case, you want
> the first. Add -fno-common to SHLIB_CFLAGS, like:
> SHLIB_CFLAGS="-fno-common"
> make sure to leave the leading space as it is in configure.
> And in the SHLIB_LD string, change '-single_module' to '-
> flat_namespace'. That has worked for me so far with 6.0.1 and
> 6.1CVS. I still need to try different combinations, but this works
> so far.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
