[GRASSLIST:8570] Re: Changing scale of raster map
Bruno GUILLAUME
guib at aero.obs-mip.fr
Mon Oct 10 11:20:48 EDT 2005
Ian,
thanks for your prompt reply. Let us talk about my raster, say "toto"
(unit=kg).
Well, in fact, my initial resolution for toto is 00:00:30 but it is full
world map (=933120000 grid cells in total!), so it is not easily
portable in flat ASCII format!! So, I prefer to convert it first to a
resolution of 1°x1° (this resolution is largely enough for my goals).
The problem is that after using the g.region command to convert it, I
check out the conservation of mass and my problem is that I do not get
the same total amount of kg (unit of toto) with r.sum rast=toto under
00:00:30 resolution and under 1° resolution !
So, I suppose that g.region do not accumulate the field of values
represented in toto (unit=kg) but rather interpolate it.
So what does it do exactly ? And how can I get it to change resolution
with mass-conservation of the field in toto, so that the value in one
big grid cell of toto in 1°x1° resolution be equal to the sum of all
little grid cell values (of resolution 00:00:30) comprised in the big
cell ?
Hope this problem is clearer expressed,
Bruno.
Ian MacMillan wrote:
> Bruno, first thing, in a latlong projection, the units of resolution
> are given in degrees. So ewres=1 means that your cell width is one
> degree. Most other projections have a cell unit of meters. For
> example an ewres=1 in an UTM projection would mean that your cell
> width is one meter. To change your resolution, you can use
> g.region res=your_res
> for example
> g.region res=00:00:30 yields a 30 arc second resolution in a latlong
> projection.
> Hope this helps,
> Ian
> On Oct 10, 2005, at 7:35 AM, Bruno GUILLAUME wrote:
>> Dear GRASS users,
>> My problem concerns a raster in lat-lon projection, having a given
>> resolution of ewres1,nsres1. For every cell, the category value is
>> expressed in kilogram.
>> I need to transform it into the same grid but with coarser
>> resolution, say ewres2=10*ewres1 and nsres2=10*nsres1, BUT the
>> transformation need to be mass-conservative (so, I need to get
>> exactly the same amount in kilograms with finer and coarser resolution).
>> Can I do in a simple way with GRASS ?
>> Thanks in advance,
>> Bruno Guillaume.
> What happens if a big asteroid hits Earth? Judging from realistic
> simulations involving a sledge hammer and a common laboratory frog, we
> can assume it will be pretty bad.
> - Dave Barry
> This message has been scanned by Postini anti-virus software.
