[GRASSLIST:8591] Re: i.points :coordinating system?
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Wed Oct 12 07:33:41 EDT 2005
Josip, I think that you are supposed to enter coordinates as whatever
your target location is. So if you are projecting into a latlong, use
degrees. Be careful with dd:mm:ss.sss vs. dd.ddddd. I think you might
need to append the directional modifier as well (N,E,S,W) for the
dd:mm:ss case. For example 30:28:55.45N.
Hope this helps,
Ian
On Oct 12, 2005, at 4:16 AM, Josip Vrlić wrote:
> Hello!
> I want to ask something about module i.points
> First I mark one point on map, and then I have to insert real
> coordinate for that point.
> I want to ask can coordinate be in Latitude-Longitude or is MUST be in
> UTM???
> Coordinate system on target LOCATION is set to Latitude-Longitude
> system.
> Thanks!
> Josip Vrlic
This message has been scanned by Postini anti-virus software.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051012/0420706f/attachment.bin
