[GRASSLIST:8606] Re: Recommended OS
    Konstantinos Theofilis
    theofilis at macland.gr
    Thu Oct 13 13:04:02 EDT 2005
Ι do not want to start OS wars here... Just an opinion
Since you say you had "some UNIX experience in the distant past",
stick to MacOS X (especially since you already have the Powermac). If
you did not have the PowerMac already, and you owned a x86 box, then
my answer may was different (because of the extra cost).
Kostas
On 13 Oct 2005, at 13:20, David Van Vliet ((personal)) wrote:
> hello GRASS community!
> I am planning to implement GRASS on a workstation, but I can't
> decide if I
> should use Linux/Fedora or MacOS on a PowerMac.  Can anybody recommend
> something?  I have some UNIX experience in the distant past, but do
> not have
> experience with either of these OS's.
> Thanks,
> Dave Van Vliet (Guelph, Ontario, Canada)
> David Van Vliet, M.A.Sc., P.Eng.
> AquaResource Inc.
> Ph:   (519) 489-4585 (Canada)
> Ph:   (267) 765-5644 (US)
> Fax:  (519) 699-4982
> Web: http://www.AquaResource.ca
> eMail:  dvanvliet at AquaResource.ca
> The contents of this email and any attached files are confidential and
> intended solely for the use of the individual to whom they are
> addressed.
> If you are not the intended recipient, please delete all copies and
> notify
> AquaResource Inc. immediately.
