[GRASSLIST:8622] Bus route on Grass
RAVI KUMAR ravivundavalli at yahoo.com
Fri Oct 14 04:42:58 EDT 2005
Hi All,
want help to bring grass nearer to people, by giving simple solutions.
I have made the following
1. Digitized my cities bus route map as dxf (Qcad) and imported to GRASS6
2. Each bus route is a small line, and the piling of all bus lines is the result.
3. Important locations of stations (bus stops) are given as point information.
What is needed
1. Through network analysis, the display show the shortest path, BUT HOW TO GET
A. List of all bus stations in the route
B. Bus numbers to change, with minimum bus change preferred.
Example: Inthe short route one can travel the path buy a dozen bus changes or just 2 or 3.. HOW TO INSERT THIS LOGIC.
Thanks in anticipation..
Ravi Kumar
 Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051014/81dc696c/attachment.html
