Hello at every. Exposing my problem : i must rear a map multilayers in Grass,for strength dial i must do does the stop at edict v.db.addtable. In the version by myself install , Debian , this command not it is present , in order to make available it,i must update the package containing does the command? Thanks, Dina.
