[GRASSLIST:8650] Re: update grass6
Hamish
hamish_nospam at yahoo.com
Sun Oct 16 19:07:11 EDT 2005
> Exposing my problem : i must rear a map multilayers in Grass,for
> strength dial i must do does the stop at edict v.db.addtable.
> In the version by myself install , Debian , this command not it is
> present ,
> in order to make available it,i must update the package containing
> does the command?
It is new and not in GRASS 6.0. But v.db.addtable only does this:
echo "CREATE TABLE $table ($GIS_OPT_columns)" | db.execute
You you can just type that at the command prompt.
see the db.execute help page for usage examples.
http://grass.ibiblio.org/grass61/manuals/html61_user/db.execute.html
Hamish
