[GRASSLIST:8784] Re: proj_api.h
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu Oct 27 14:50:01 EDT 2005
Hello
On Thu, 27 Oct 2005, M S wrote:
> i see the configure flags to point it to the various proj external areas,
> but i cant find this proj_api.h on my system at all except for in the grass
> dir of gproj_api.h.
> i'm running FC4.
> i have proj 4.4.9-1 installed.
proj_api.h should come with PROJ.4. Maybe your operating system has PROJ.4
split into separate development and runtime packages? You would need the
development package installed to compile GRASS. Just a guess. Someone else
on the list could probably tell you a command to run to find out the package
you need.
Paul
