[GRASSLIST:8785] Re: proj_api.h
    M S
    mseibel at gmail.com
    Thu Oct 27 14:57:22 EDT 2005
nice catch... its probably the proj-devel i need!
On 10/27/05, Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> Hello
> On Thu, 27 Oct 2005, M S wrote:
> > i see the configure flags to point it to the various proj external
> areas,
> > but i cant find this proj_api.h on my system at all except for in the
> grass
> > dir of gproj_api.h.
> > i'm running FC4.
> > i have proj 4.4.9-1 installed.
> proj_api.h should come with PROJ.4. Maybe your operating system has PROJ.4
> split into separate development and runtime packages? You would need the
> development package installed to compile GRASS. Just a guess. Someone else
> on the list could probably tell you a command to run to find out the
> package
> you need.
> Paul
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051027/740aa916/attachment.html
