[GRASSLIST:8798] Re: g.mapset OR g.gisenv (GUI wishlist discussion)
Hamish
hamish_nospam at yahoo.com
Fri Oct 28 05:46:10 EDT 2005
On Sat, 23 Jul 2005 16:09:21 -0400
> having posted a wish to be able to move between mapsets and locations
> without closing out of GRASS I was given two options from two people
> (ref bug#3456).
> One was g.mapset and the other is g.gisenv. Some questions.
> 2. Can a button be built in to show ALL mapsets and coresponsing
> locations for either or both of these. This could enhance the gui
[replying to another old email, but a handy hint]
have a look at g.mapsets for setting which mapsets are in the map name
search path, and also be aware of the mapname at mapset syntax which isn't
well documented outside of the books. And "g.list rast mapset=..."
i.e. you can access maps from different mapsets without switching.
For a location (change of map projection), you'd need to use the *.proj
modules to bring the map into the current location/mapset or use a
different GRASS session.
Hamish
