[GRASSLIST:8799] Re: operations on subsets of data in database
Fri Oct 28 06:05:37 EDT 2005
On Thu, 28 Jul 2005 23:32:20 -0400
Jason Horn <jhorn at bu.edu> wrote:
> I figured out how to set up attribute data for a point layer in a
> mysql database.  Very handy because I can now select points for
> display based on attributes (population > n, type like "whatever",
> etc.)  However, now I want to perform operations on those data based
> on the same select criteria.  For example, I want to create buffer
> vector layer from just some of the points in that point layer.  There
> does not appear to be any way to do this in GRASS.   I would have to
> create a copy of the layer or a new layer that contains a subset of
> the points.
[more old emails...]
v.extract where=<SQL query>
Many vector modules have similar functionality.
Hamish
