[GRASSLIST:8811] Re: concurrent sessions from a shell script
Sat Oct 29 13:12:50 EDT 2005
Upendra wrote:
> In general, could there be any problem if I am running in parallel two
> different grass commands from two different script files on two
> entirely different raster files, but in the same location and mapset.
Yes.
The most obvious source of potential conflict is the mapset's WIND
file.
However, so long as the two scripts don't try to create maps with the
same name, and don't try to modify the region, you can probably get
away with it. Essentially, it's your responsibility to ensure that no
conflicts occur.
Is there some reason you can't create a separate mapset for each
"session"?
