[GRASSLIST:8820] Re: Problems with v.overlay
Radim Blazek radim.blazek at gmail.com
Mon Oct 31 03:23:19 EST 2005
It can be that you found a particular case (geometry) where it fails.
Please try to separate the lines causing problem (with v.select take
always half of input, half of half etc.) and send the minimum
(few lines) maps here.
Radim
On 10/28/05, Wolf Bergenheim <wolf+grass at bergenheim.net> wrote:
> Hi!
> I'm having problems with v.overlay and operator=or.
> I try to merge two similar vector maps, and it seems that it goes nuts
> while trying to break lines... It continues to work for a long time (an
> hour or more) and then it is killed. Could anyone help me out with this?
> Or has anyone seen this before?
> I'm using the newest CVS checkout, so 6.1. As a side note I'm using a
> powerpc computer (A Blue-White G3 mac), running Debian Linux. I was able
> to make some sort of an intersection by using the cygwin grass61, but
> now I must do it with my G3.
> --Wolf
> <:3 )---- Wolf Bergenheim ----( 8:>
