[GRASSLIST:8821] Re: switching to postgres
Radim Blazek radim.blazek at gmail.com
Mon Oct 31 03:49:15 EST 2005
On 10/28/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> AFAIK the database needs to be created before. If you would just
> copying your existing tables to PG, you should consider using db.copy
> and reconnect the newly created tables in PG with your dataset (with
> v.db.connect)
Or
g.copy vect=
g.remove vect=
Radim
