[GRASSLIST:8164] Re: lon/lat to utm ?
David Finlayson
david.p.finlayson at gmail.com
Fri Sep 2 11:24:16 EDT 2005
or you can just use proj directly on the corners, something like this:
echo -122.5 47.0 | proj +proj=utm +zone=10
David
On 9/2/05, Ian MacMillan <ian_macmillan at umail.ucsb.edu> wrote:
> Ahmet, use v.in.region to create a box in your latlong location of your
> current region. Open up a utm location, and v.proj in that box. Then
> use v.info for information about the box that you just projected.
> There may be an easier solution, but this one will work at least.
> G'luck
> -Ian
> On Sep 1, 2005, at 11:49 PM, orkun wrote:
> > hello
> > my map region is in lon/lat projection.
> > how can I get utm values of this region ?
> > regards
> > Ahmet Temiz
> > ______________________________________
> > XamimeLT - installed on mailserver for domain @deprem.gov.tr
> > Queries to: postmaster at deprem.gov.tr
> > The views and opinions expressed in this e-mail message are the
> > sender's own
> > and do not necessarily represent the views and the opinions of
> > Earthquake Research Dept.
> > of General Directorate of Disaster Affairs.
> > Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> > olarak T.C.
> > B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> > nitelikte degildir.
> What happens if a big asteroid hits Earth? Judging from realistic
> simulations involving a sledge hammer and a common laboratory frog, we
> can assume it will be pretty bad.
> - Dave Barry
> This message has been scanned by anti-virus software.
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
