[GRASSLIST:8199] Re: Grass6.0.1 Binaries for Mandrake 10.0
    Otto Dassau
    dassau at gdf-hannover.de
    Wed Sep  7 12:38:50 EDT 2005
On Wed, 7 Sep 2005, Alejandro Hinojosa wrote:
> Answering Otto an Michelle,
Hi Alejandro,
> I didn't force any of the package installation with the -f switch, actually
> there were only two fixes. The dependencies that had to be resolved are
> gdal-1.3.0-2mdk10.1.i586.rpm  asked for libstdc++.so.6
> and
> grass-6.0.1-2mdk10.1.i586.rpm  asked for libfftw.so.2
> and regarding Michelle's comment that this is not a grass issue,
> unfortunately to get grass running you need to know something about make, rpm
> (or equivalent),shell scripts, root privilegdes  and package installation, at
> least it helped me get it running. I hope I didn't mess something else.
you are right - the fftw dependency can easily be resolved with the
original mandrake 10.0 rpm libfftw2-2.1.5, but for libstdc++.so.6, what
package or procedure resolved the libstdc++.so.6 dependency? Or did you
compile sources?
Was it possible to simply install the libstdc++6-3.4.0-0.4mdk.i586.rpm
from mandrake > 10.0. Maybe you could describe what you did with the
necessary commands. That might help other people using Mandrake 10.0.
thanks a lot!
  Otto
> Alejandro
> At 08:26 AM 9/7/2005 +0200, you wrote:
>> Am Dienstag, 6. September 2005 23:33 schrieb Alejandro Hinojosa:
>> > Dear list,
>> Dear Alejandro,
>> > Since nobody came to the rescue but Otto , let me tell you how i fixed
>> > using the binary distribution  intended for Mandrake 10.1 in version 10.0
>> > This is to solve the dependencies of the distribution rpms. Otto
>> indirectly
>> > suggested to migrate to 10.1, but sometimes it's to much hassle to
>> > backup  everything before migrating.
>> Do you remember, what packages you had to upgrade on your mandrake 10.0. I
>> could add your information to the readme - for other users.
>> > I followed the installation sequence defined in the  readme of the
>> > distribution site for Mandrake
>> > http://www.gdf-hannover.de/media.php?id=1&lg=en
>> > then when the dependencies started to appear i went
>> > to  http://rpm.pbone.net  and searched for the libraries requested,
>> > download them and installed manually with root privileges with  rpm
>> > -ivh  package.rpm.
>> > At the end, I got grass60 to run. I hope I don't get into furture
>> problems
>> > for running on version 10.0.
>> > My first surprise, besides the interface, is that it will not see my old
>> > vectors from 5.4.
>> thanks for your comments!
>>    Otto
>> > Alejandro
>> >   At 11:22 PM 9/5/2005 +0200, you wrote:
>> > >On Mon, 5 Sep 2005, Alejandro Hinojosa wrote:
>> > >>Dear list,
>> > >Dear Alejandro,
>> > >>I have Mandrake 10.0 running on my pc box and downloaded the rpm
>> binaries
>> > >>for grass 6.0.1 from gdf-hannover.
>> > >>Will this version run under Mandrake 10.0?
>> > >>I started following the installation order from the readme,
>> > >>doing  manually with   rpm -i -v  package.rpm . The first package
>> > >>(proj-4) installed without trouble, but  didn't know where it was
>> > >>installed. For the second package (gdal-1.3.0-2mdk10.1.i586.rpm) the
>> > >>installation  aborted with errors:
>> > >>Failed dependecies
>> > >>libstdc++.so.6 is needed by gdal-1.3.02mdk10.1
>> > >>under /usr/lib there is a libstdc++.so.5  but no libstdc++.so.6,
>> > >>Any clues, directions? Do I need the Mandake 10.1 or a  symbolic link
>> > >>from libstdc++.so.6 to libstdc++.so.5 will do.
>> > >you can try a symbolic link, but I don't think this will work. The
>> > >packages are compiled on a mandrake 10.1 and unfortunately not build for
>> > >Mandake 10.0 - sorry.
>> > >   otto
>> > >>Thanks
>> > >>Alejandro Hinojosa
>> > >>Geology Department ,Earth Sciences Division
>> > >>CICESE
>> > >>Ensenada, Baja California, Mexico
>> > >>Alejandro Hinojosa
