[GRASSLIST:8205] Re:Re: libgrass_gmath.so error on startup (FC4)
Michele michele.rocc at libero.it
Thu Sep 8 04:13:21 EDT 2005
Chris,
> The error message is:
> GRASS 6.0.1 (spearfish60):~/grass > Error in startup script: ps.map:
> error while loading shared libraries:
> /usr/local/grass-6.0.1/lib/libgrass_gmath.so: cannot restore segment
it seems that the GRASS package you installed was compiled with some libraries you don't have,
search in your sistem for libgrass_gmath.so,if you find send the output, if you don't find you maybe have to install lapack (maybe your binaries was build upon it, even if grass dont use it for now).
Michele.
