[GRASSLIST:8209] Re:Re: libgrass_gmath.so error on startup (FC4)
    Tom Colson
    tom_colson at ncsu.edu
    Thu Sep  8 09:23:37 EDT 2005
Post your configure coammand
Thomas Colson
North Carolina State University
Department of Forestry and Environmental Resources
(919) 673 8023
Calendar:
www4.ncsu.edu/~tpcolson
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Michele
Sent: Thursday, September 08, 2005 4:13 AM
To: chris_bennett
Cc: GRASSLIST
Subject: [GRASSLIST:8205] Re:Re: libgrass_gmath.so error on startup (FC4)
Chris,
> The error message is:
> GRASS 6.0.1 (spearfish60):~/grass > Error in startup script: ps.map:
> error while loading shared libraries:
> /usr/local/grass-6.0.1/lib/libgrass_gmath.so: cannot restore segment
it seems that the GRASS package you installed was compiled with some
libraries you don't have, search in your sistem for libgrass_gmath.so,if you
find send the output, if you don't find you maybe have to install lapack
(maybe your binaries was build upon it, even if grass dont use it for now).
Michele.
