[GRASSLIST:8208] Re: MrSID and incorporating the .sdw info into resulting GeoTiff.
Richard Greenwood
richard.greenwood at gmail.com
Thu Sep 8 09:13:21 EDT 2005
On 9/7/05, Craig Aumann <caumann at ualberta.ca> wrote:
> I have a bunch of .sid files that I am converting to GeoTiffs. How
> does one incorporate the spatial location information in their
> associated .sdw file into the associate .tiff file?
> Here's what I am doing:
> mrsiddecode -i FILE.sid -o FILE.tif -of tifg
> ## Use the code for NAD27, Zone 12
> ## contained in EPSG file: /usr/share/proj/epsg
> gdal_translate -of GTIFF -a_srs '+init=epsg:26712' \
> FILE.tif FILE.NAD27.tif
> But when I do a gdalinfo, it is clear that the information in the .sdw
> file has not been used (the "file.sdw" is given below):
> gdalinfo file.tif
> Driver: GTiff/GeoTIFF
> Size is 9168, 9168
> Coordinate System is:
> PROJCS["NAD27 / UTM zone 12N",
> GEOGCS["NAD27",
> DATUM["North_American_Datum_1927",
> SPHEROID["Clarke 1866",6378206.4,294.9786982138982,
> AUTHORITY["EPSG","7008"]],
> AUTHORITY["EPSG","6267"]],
> PRIMEM["Greenwich",0],
> UNIT["degree (supplier to define
> representation)",0.01745329251994328],
> AUTHORITY["EPSG","4267"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-111],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","26712"]]
> Origin = (-0.500000,9167.500000)
> Pixel Size = (1.00000000,-1.00000000)
> Corner Coordinates:
> Upper Left ( -0.500, 9167.500) (115d29'19.33"W, 0d 4'57.69"N)
> Lower Left ( -0.5000000, -0.5000000) (115d29'19.32"W, 0d 0'0.02"S)
> Upper Right ( 9167.500, 9167.500) (115d24'23.63"W, 0d 4'57.72"N)
> Lower Right ( 9167.500, -0.500) (115d24'23.61"W, 0d 0'0.02"S)
> Center ( 4583.500, 4583.500) (115d26'51.47"W, 0d 2'28.84"N)
> The associated .sdw file is:
> 1.200000000000000
> 0.000000000000000
> 0.000000000000000
> -1.200000000000000
> 492501.000000000000000
> 6243621.000000000000000
Try renaming the .sdw file to .tfw
Also try gdalinfo on the file.tif to be sure that the original reference system
is "seen".
Regards,
Richard Greenwood
www.greenwoodmap.com
