[GRASSLIST:8220] Re: libgrass_gmath.so error on startup (FC4)
Tom Colson
tom_colson at ncsu.edu
Thu Sep 8 22:33:25 EDT 2005
Look at all my posts to this forum: I had the same problem, traced it to a
FFTW build error, which the gmath libs depend on (I think). Marcus posted a
fix for me, I can't remember if it was public or not. I had to apply a patch
to the gmath binaries directory....
If you can't find it, I'll boot into my Fedora install over the weekend and
post my config log for you.
http://grass.itc.it/cgi-bin/htsearch?restrict=;exclude=;config=htdig;method=
and;format=builtin-long;sort=time;words=colson;page=5
Can you post your config log, OS version, and version of GCC? (and
platform...is it X64?)I'm no expert, I had a horrible time getting it all
compiled and working, and can share what the community did to help me out
some months ago.
Why are you compiling with no C++ support? Try xcc=yes...and try turning off
Postgres till you get gmath working....there's a lot you can't do without
gmath.
Thomas Colson
North Carolina State University
Department of Forestry and Environmental Resources
(919) 673 8023
Calendar:
www4.ncsu.edu/~tpcolson
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Chris Bennett
Sent: Thursday, September 08, 2005 10:00 PM
To: GRASSLIST at baylor.edu
Subject: [GRASSLIST:8219] Re: libgrass_gmath.so error on startup (FC4)
Michele: libgrass_gmath.so is found in
/usr/local/grass-6.0.1/lib/libgrass_gmath.so which is the install directory.
Tom: My configure command is
CFLAGS=-O2 ./configure --with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib
which results in
C compiler: gcc -O2
C++ compiler:
FORTRAN compiler:
Building shared libraries: yes
NVIZ: yes
X11 support: yes
JPEG support: yes
TIFF support: yes
PNG support: yes
Tcl/Tk support: yes
PostgreSQL support: yes
MySQL support: no
OpenGL(R) support: yes
ODBC support: no
FFTW support: yes
BLAS support: no
LAPACK support: no
Motif support: no
FreeType support: no
GLw support: no
NLS support: no
Readline support: no
C++ support: no
openDWG support: no
GDAL support: yes
OGR support: yes
It does seem kinda strange that C++ support is off by default. Should that
be turned on?
Thanks all.
-Chris.
