[GRASSLIST:8225] Re: How to set up a Linux system for GRASS6.01
Trevor Wiens
twiens at interbaun.com
Fri Sep 9 11:30:47 EDT 2005
On Fri, 09 Sep 2005 08:36:21 -0600
Feng Wordsworth <fengwordsworth at shaw.ca> wrote:
> Hi, List,
> I am new to GRASS and want to know how to setup GRASS6.01/PostgreSQL/R in a Linux enviroment, what kind of hardwere do I need? Configrations? How can I do it step by step?
> Thanks,
> Dave
This would depend on what Linux distro you are running. PostgreSQL and R should be pretty basic installs on any rpm or deb based system. To look for rpms or deb or tar balls look at the GRASS home page.
Once everything is installed and running, you will need to setup a database under PostgreSQL that your user of GRASS will have access to. At this point you can then connect using db.connect. If you want to access your attribute data outside of GRASS you might want to look at using PgAdminIII.
For the use of R please with GRASS please refer to the geostats section on the GRASS homepage under applications.
T
Trevor Wiens
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
(Daniel J. Boorstin)
