[GRASSLIST:8247] Re: Installation errors
Chris Bennett
chris_bennett at comcast.net
Mon Sep 12 21:23:33 EDT 2005
I think setting LD_LIBRARY_PATH to include the library's path may help.
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/bin
export LD_LIBRARY_PATH
Put the above in your login script to make it always available.
-Chris.
Giacomo Bertoldi wrote:
> Hi all,
> I've just installed on a DELL sever with Fedora the GRASS binaries for
> Fedora Core 3, but GRASS is not working properly:
> When it starts d.m I receive the following error:
> > d.m&
> > Error in startup script: ps.map: error while loading shared
> libraries: libgdal.so.1: cannot open shared object file: No such file
> or directory
> while executing
> "exec ps.map -p"
> (procedure "DmPrint::init" line 14)
> invoked from within
> "DmPrint::init"
> (procedure "main" line 32)
> invoked from within
> "main $argc $argv"
> (file
> "/usr/local/grass6.0.0-i686-pc-linux-gnu-14_03_2005/etc/dm/d.m.tcl"
> line 894)
> [1]+ Exit 1 d.m
> Similar error with nviz
> > nviz
> nviz: error while loading shared libraries: libgdal.so.1: cannot open
> shared object file: No such file or directory
> Any solution?
> Thanks, Giacomo
> Giacomo Bertoldi
> Dept. of Civil and Environmental Engineering
> Duke University
