[GRASSLIST:8245] Re: Installation errors
    Carlos "Guâno" Grohmann
    carlos.grohmann at gmail.com
    Mon Sep 12 18:27:49 EDT 2005
This might just be a problem with libraries names. search for libgdal.so and
make a link to it named libgdal.so.1 in the same directory.
hope this helps
regards
Carlos
On 9/12/05, Giacomo Bertoldi <giacomo.bertoldi at ing.unitn.it> wrote:
> Hi all,
> I've just installed on a DELL sever with Fedora the GRASS binaries for
> Fedora Core 3, but GRASS is not working properly:
> When it starts d.m I receive the following error:
> > d.m&
> > Error in startup script: ps.map: error while loading shared
> libraries: libgdal.so.1: cannot open shared object file: No such file
> or directory
> while executing
> "exec ps.map -p"
> (procedure "DmPrint::init" line 14)
> invoked from within
> "DmPrint::init"
> (procedure "main" line 32)
> invoked from within
> "main $argc $argv"
> (file
> "/usr/local/grass6.0.0-i686-pc-linux-gnu-14_03_2005/etc/dm/d.m.tcl"
> line 894)
> [1]+ Exit 1 d.m
> Similar error with nviz
> > nviz
> nviz: error while loading shared libraries: libgdal.so.1: cannot open
> shared object file: No such file or directory
> Any solution?
> Thanks, Giacomo
> Giacomo Bertoldi
> Dept. of Civil and Environmental Engineering
> Duke University
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050912/e95983db/attachment.html
